kailiwela44
- Senton 6s
Senton 3s BLX V3owner.
I found that there is a lot of information spread out on the net (arrmaforum, youtube, reddit, etc.) But, finding the information I’m looking for can take a while. Hopefully, I can consolidate all my questions about building, repairing, and upgrading my Senton.
Suspension. When the stock parts break, I will be doing either replacement, upgrades, and maybe both. Currently, I have the typhon 6s shocks, axles, and hubs. If an A Arms breaks, am I able to use any of the Typhon A Arms as a replacement/upgrade? I believe the width will widen, but am okay with since I can order Senton Arms too.
Tires. Since I will have an option of switching from 17mm hex and 14mm hex, what is the largest tire diameter that can be installed? I’m currently running Duratrax Faze ST.
Pinion. Since I plan to go with larger tires, is there a downside besides losing top-end speed to run 15T pinion for any size tires? Or, is there a happier medium?
Replacement body. I recall a post saying that the Traxxas Slash advertised bodies will fit the Senton 3S. True? Are there any premade body mounts that raise the body higher? I recall seeing someone replace the side guards from a BRCC to mount a MT body. Any pointers?
There will probably be more questions as I sink into this wonderful abyss. Thank you in advance.
