Brewcity414
King of questions
has anyone swapped out their Tactic receiver for this truck? Any suggestions?
Yes that's what I meant. I am new to the hobby so just wondering how customizable will this car be. ThanksDo you mean using a different transmitter? I use a Spektrum Dx5c. It’s a lot more customizable than the tactic and it allows you to pair multiple receivers to it (I have 8 on mine). The downside is the receivers aren’t cheap and my on/off button sticks (from day 1). I know there are less expensive alternatives that people use and some that are just as expensive like Futaba.
I appreciate that break down thanks for the patience. I just ordered my car and I've been reading up on the most common broken parts so thank God for these forums.TX= Transmitter = the part you hold in your had to control the car.
RX= Reciever = the small box inside the car that the ESC and servo plug into - it receives the signal from the TX and actively controls the ESC and Servo
ESC = Electronic Speed Controler = the magic box that controls the motor speed.
Spektrum receivers can be had for $12 from China https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/223156186684 or $16 from the US https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/153281997761 on ebay.Do you mean using a different transmitter? I use a Spektrum Dx5c. It’s a lot more customizable than the tactic and it allows you to pair multiple receivers to it (I have 8 on mine). The downside is the receivers aren’t cheap and my on/off button sticks (from day 1). I know there are less expensive alternatives that people use and some that are just as expensive like Futaba.
I meant the remote sorrySpektrum receivers can be had for $12 from China https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/223156186684 or $16 from the US https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/153281997761 on ebay.
You still need a different receiver if you swap out the remote. This is literally the only other land rc remote that tactic makes, everything else is for air vehicles https://www.tacticrc.com/transmitters/tacj0200/index.phpI meant the remote sorry
Thanks a lot for breaking that down I never knew that. #screenshotYou still need a different receiver if you swap out the remote. This is literally the only other land rc remote that tactic makes, everything else is for air vehicles https://www.tacticrc.com/transmitters/tacj0200/index.php
Each brand uses their own modulation so as an example you can't run a Spetkrum DX5C transmitter with a Tactic TR326 receiver. The Spektrum uses DSMR and DSM2 modulation the Tactic TTX300 uses SLT modulation.
I tried AVC on my LC Racing truggy and no matter how much I messed with it the car would just steer wherever the hell it felt like. So I shut it off and haven't messed with it since.Display and endpoints is my first concern if I'll spend up to $100. Speed to Rx must be more affordable than what Spektrum offers even with avc or whatever unless there's a substantial benefit that I can't see yet. I have one 2wd truck and use the traxxas system and it works well enough. I do like the bt app ok and ability to tune it slower for young cousins and nephew. Otherwise I can't see getting into new proto just yet but will look at more of his videos for sure.
Will the spectrum/futaba tx bind with the tatic rx, that is the standard makes 3chDo you mean using a different transmitter? I use a Spektrum Dx5c. It’s a lot more customizable than the tactic and it allows you to pair multiple receivers to it (I have 8 on mine). The downside is the receivers aren’t cheap and my on/off button sticks (from day 1). I know there are less expensive alternatives that people use and some that are just as expensive like Futaba.
NoWill the spectrum/futaba tx bind with the tatic rx, that is the standard makes 3ch
