I'm converting my Arrma Senton 3s to a Typhon 3s. (Or Syphon) After bashing for a few months I've noticed that my body is breaking so often because I land on it so much. I went to order a new one and realized that the Typhon body was about half the price. Looking at my cousin's Typhon body, he doesn't even have a crack in it because when he flips over it doesn't touch the ground. I decided I was going to get Typhon body mounts and a body. I'm getting bigger tires and a smaller pinion too. I'm hoping to save a little money on cheaper bodies and them lasting longer along with me liking the Typhon look more now. I'm planning on leaving the senton bumper on because it's bigger but changing the rear bumper.
Next I'll probably 3d print the rear wing (Thanks Camaroboy383 for modeling it) and the rear wing mount (Thanks suchtragedy). I might be 3d printing some bigger tires with big teeth for the dirt, not sure yet tho. Still have to model them and not sure how hard it will be since I just installed meshmixer last night as I have been using sketchup. Sketchup hasn't worked good for printing as it fills in holes in some layers and makes holes where it should be filled in.
Front Body Mounts:
https://www.amazon.com/Arrma-AR3204...dy+mounts&qid=1610651205&sr=8-2&&tag=arrma-20
Rear Body Mounts:
https://www.amazon.com/Arrma-AR320452-Body-Mount-Typhon/dp/B07HZ5NPWP
3d Models:
Typhon 3s Wing by camaroboy383:
https://www.thingiverse.com/thing:4152440
Typhon 3s Wing Mounts by suchtragedy:
https://www.thingiverse.com/thing:4503718
TRB Bearings:
https://www.amazon.com/Arrma-Granit...ords=TRB+senton+bearing&qid=1611952552&sr=8-2
Typhon Body:
https://jennysrc.com/products/arrma...uggy-ar402274-ar102696?variant=19223393468470
I got the body and body mounts on. Looks kinda stupid right now without the rear wing and the junk tires on. The bumpers make it look dumb too.
My bigrock tires, bigrock pinion, and typhon bumpers just arrived today. Can't wait to put them on and try it out.
Bigrock Tires (dBoots RAGNAROK):
https://jennysrc.com/collections/ar...es-wheels-tyres-rims-dboots-ragnarok-ar102711
Bigrock Pinion:
https://jennysrc.com/collections/ar...shaft-granite-ar102711?variant=19198466359350
Typhon Bumpers:
https://jennysrc.com/collections/ar...lx-bumpers-ar320454-front-rear-mega-ara4306v3
Tires, pinion, and bumpers on. The rear wing is 3d printing right now. I rode it at 75% power without changing the pinion to see the speed, and it rips! I didn't want to do 100% power with the 20T pinion for fear of overheating the motor. I don't understand why nobody else does this, it looks sick, rides great, and isn't an expensive change. It should look even better when I get the rear wing and wing mounts on. The next upgrade I think will be a better servo. With the bigger tires, extended hub thingies on the tires, and the fact that my servo is already junk. I think it's now safe to call it a Syphock (Senton/Typhon/Bigrock)
I'm not sure if i'm going to be putting a SWB Granite chassis in it because I would either have to get a Granite body OR cut the rear of the Typhon body a few inches and re-drill the holes. I think I will leave it for now and see how it runs then maybe that will be a future project.
Front Body Mounts:
Rear Body Mounts:
3d Models:
TRB Bearings:
Typhon Body:
Bigrock Pinion:
Typhon Bumpers:
