Senton senton 3S BLX V3 AR610046 Bearing replacemet?
arrmaKen
  1. Senton
Anyone know a good quality aftermarket replacement for the slipper clutch bearings? part AR610046? A search on the forum here for that number gave no results. thanks.
arrmaKen
  1. Senton
Yes ive found different webpages with 16 different bearings or more to choose from before is the reason for asking here. Any forum members know which specific ones are known to work out for people here for longevity? Thanks
jondilly1974
Speed running apprentice, 3D printing fool
ArrmaForum Fan
Solutions
1
Toledo, OH
  3. Typhon 6s
  4. Typhon 3s
Is yours flanged or not? Arrma has used two different styles
I also found that these slipper clutch bearings were very bad on my Granite 3S V3.
I replaced them with Fast Eddy Bearing 10x15x4.
If you go with Fast Eddy, I suggest you lift the rubber seal, verify how much grease there is and add grease if needed prior to installation. I had several bearings low on grease in my Fast Eddy kit.
arrmaKen
  1. Senton
Non flanged here, there are a number of different 10x15x4, thanks.
