Johnny b
Hey guys...as it states. First run. Proline trenchers, 15 tooth pinion. Everything else 100% stock. I did research cogging issues extensively prior to posting. Let me add that the trencher tires are very close to stock size. New to electrics but I'm certain its cogging. Need your expertise in helping me minimize it if possible. Adding a sensored system is not yet an option. My pinion mesh is perfect around the entire spur. Bearings intact and functioning smooth everywhere. Did not tear into the motor just because its new. Visually inspected all connection wires between motor and esc . I believe slipper clutch is properly set. My thought Is start with the easy things. Threw the stock tires back on and look for change, then perhaps adjust punch? I'm not sure where its at now but know how to change it. Finally, I'm running a smc 3s 5200 135c pack. Having said all that, In my excitement, I never got the tx off 75%. A stupid fast wheelie machine.
Loving it!.... appreciate your input and knowledge. Thanks!
