This is what I should try first also.Your LHS should be able to loan you a lipo for a run in the parking lot.
Exactly. Two devices are saying your lipo is sh!t but you think it’s not the Lipo ???What type of connector is on the ESC? Is it the one it came with or has it been changed. If it's been changed, who soldered it? Are you using any adapters. The one thing that I find interesting is this:
So the external alarm also detected a low voltage situation. So both the ESC are sensing a voltage drop.
EC3
Both batteries have EC3 connectors on them so I don't need an adapter.
I did the exact same thing as #1 when I was new to lipo. Don’t beat yourself up. ??Ok so I tested the first battery I purchased, the Lectron Pro 3S 5200mAh 50C.
1) Charged fully *I did learn something potentially critical (I'm a little embarrassed to admit but for science I will make that sacrifice) that there was a setting on my charger - kinda like a backup Killswitch - that limits the capacity to prevent overcharging. The default setting is 5000mAh. I did not change the setting as the directions aren't really clear about how that should be set and as a newby I was paranoid about starting a fire... That's my excuse. Not sure if it was the culprit though.
2) Checked ran the IR Meter Program and the battery read 6.3 mO. Now the support guy said 2-6 is normal so I'm not sure what being 6.3 makes the battery. But from what I've seen online this battery doesn't appear to be race-worthy at that number and accordjng to Lectron support is at the high end of resistance that would be considered "normal".
3.) Discharged the battery the fun way. The vehicle ran without issue until the motor got too hot and it went into limp mode but I am certain it was do to running nonstop in grass from 4.2v to 3.76v when I stopped.
4) I ran the IR Meter on the battery at 3.76v and it read 23.4mO
So it did run better but is 6.3mO too much resistance and perhaps indicative of a faulty battery? And is normal to be so high with .36v remaining before LVC?
Same here, but my hangup was the timer which I had unknowingly left at 30 minutes. That was NOT enough time to charge from LVC. I watched like a hawk every time I had to start it up for a second time to get a full charge...I did the exact same thing as #1 when I was new to lipo. Don’t beat yourself up. ??
It's the Lectron Pro AC-DC10a charger.Which charger are you using? Some (most?) of the IR meters are pretty unreliable, and totally fluctuate depending on whether the battery is charging, discharging, etc.
Not sure when you run it it just says Main Out: 6.3mO. I guess I didn't try to see if it broke it down or if this is an average or what. I'll try that tonight when I test my other battery.Your readings are they total or each individual cell IR readings?
2-6 is what should be considered normal for each individual cell in the battery IMO.
Thanks for the tip. Just curious, what is the importance of running down to 3.4v per cell prior to charging it? I'll try this this weekend on both batteries. It may be premature but I am hoping the issue was just with that mAh limit that was too low by default.You don't check ir immediately after charging or at 3.7v or at storage voltage as it will always give you a false reading.
Discharge the battery down to 3.4v per cell then charge the battery to 4.2v per cell now here is the important step wait an hour for the battery to get to room temperature then check the ir.
