gramser57
I used traxxas part#5353X for the wheel hubs and it fit perfect no modifications needed, also slapped on Proline Prime 2.8 wheels, light kit and LED light bar. Happy Holiday's my dude's.
To compare with the Granite BLX 3S tires these ballon less, on warm days these tires get sticky as hell and recommend them for asphalt bashing but right now its winter conditions where I live and they are sketchy.I want this tire for my Big Rock Crew Cab for making high speed pass. This tire are good for top speed or too much balloning effect gramser57 ?
The Traxxas will work perfect with buggy wheels as its the same one Jaytee RC uses in this video:I'm looking to fit buggy wheels on my Senton, i tried 2 adapters already and both had too much play, also, additionally, since the stock wheels have some offset to them, the buggy wheels sit narrower than optimal.
The only solution that have offset built in that i found are the HR 12mm to 17mm adapter, which has 6mm offset, but i'm not sure if it's too much, and if it will cause rubbing. it is also really expensive.
The Traxxas part also doesn't seem to provide offset.
Did someone find a good solution for fitting buggy wheels on the Senton?
Nice job! Happy holidaysI used traxxas part#5353X for the wheel hubs and it fit perfect no modifications needed, also slapped on Proline Prime 2.8 wheels, light kit and LED light bar. Happy Holiday's my dude's.
Which lights ? And what does your internals look like where you plugged them all InNice job! Happy holidays
what lights did you use?
