That senton 4x4
- Senton 3s
Hi i was wondering what i could put in my senton 4x4 for diffs? im trying not to break the bank coz im trying to get a brushless hobbywing. thanks!
that would work but im looking at staying away from arrma partsYou could get the metal diffs arrma offers. If you have a v3 senton then you could just put the Brushless system in it
Arrma is the cheapest option. @Notorious J runs his diffs on 6s. If not Arrma then go with hot racing.that would work but im looking at staying away from arrma parts
ok thanks manArrma is the cheapest option. @Notorious J runs his diffs on 6s. If not Arrma then go with hot racing.
thanks manYup what Exc3l said Arrma and Hot Racing are the only 2 options.
Hot rCing is out of stock and no date on when be back in I checked a week ago with them by email. I wanted to upgrade mine to all metal not just the gears.Arrma is the cheapest option. @Notorious J runs his diffs on 6s. If not Arrma then go with hot racing.
These work good but I put 4to6s and difss leak a bit.
Do you use the rubber gasket that came on the stock diffs? I have silicone plugs in mine so IDK.Hot rCing is out of stock and no date on when be back in I checked a week ago with them by email. I wanted to upgrade mine to all metal not just the gears.
In a 3s? No I do not use plugs nor even on my 6s.Do you use the rubber gasket that came on the stock diffs? I have silicone plugs in mine so IDK.
