- 4x4-Mega
- Senton 6s
So I recently got a brushed Senton in a trade. After I get it fully running, I will be converting to BLX driveline (diffs, slipper, etc) My main problem right now is that my gearing maxed out on my 2600kv 3660 motor, is not enough. I put everything in the gearing calc, and it says top speed on 2s is about 20mph. Even with the BLX Gearing (diffs & spur/pinion), it was quite mild. I was wondering if there are any smaller spur gears that fit the BLX or Mega slipper clutch that I can use rather than getting a higher KV motor.
I did more calculating and found that a 4300kv motor is perfect for my application, but I'd really rather not buy a new motor immediately
