RJUK
What's the benefit of that over the 123? I bought the 123 off of WoodIE's recommendation.Get the 124 extra large
?? Extra large so it’s more durable ?? I was just going by multiple recommendations from other members and my own personal use.What's the benefit of that over the 123? I bought the 123 off of WoodIE's recommendation.
It still appears that the actual parts where the steering part and the servo itself connect are the same size though - I.E. the mounting hole is the same diameter for the screw that mounts the steering arm, there's just a ton more plastic around it with more holes to give you (I guess) more options for different places to screw into. Not sure that's needed for our application though as I guess we just want to screw into the central most hole??? Extra large so it’s more durable ?? I was just going by multiple recommendations from other members and my own personal use.
Yes you may have to trim it.It still appears that the actual parts where the steering part and the servo itself connect are the same size though - I.E. the mounting hole is the same diameter for the screw that mounts the steering arm, there's just a ton more plastic around it with more holes to give you (I guess) more options for different places to screw into. Not sure that's needed for our application though as I guess we just want to screw into the central most hole?
The 124 needs trimmed a lot to fit in the 4x4 rigs.Do servo savers tend to get broken very often? If I ever break the 123 I'll try the 124 to see what the difference is. There's not a lot of room in that general area so I guess there can't be a huge difference in size between the two overall. I must admit the linkage with the 123 seemed more flimsy than the Arrma servo saver as the Arrma one connected above and below the steering arm whereas the Kimbrough only connects on one side.
Sounds like you might be trimming off all the extra that you're getting over the 123 then?! Unless some other part of it is stronger as well? Visually, it just looks like the end that connects to the steering rod is larger (and it's made from black plastic rather than white). So if you're trimming that off to make it fit then perhaps you're better off getting the 123, which seems to be essentially a pre-trimmed 124...?The 124 needs trimmed a lot to fit in the 4x4 rigs.
Could be. I was under the impression that the spring or what have you inside the center was beefier. Again, just an assumption on my part. ??Sounds like you might be trimming off all the extra that you're getting over the 123 then?! Unless some other part of it is stronger as well? Visually, it just looks like the end that connects to the steering rod is larger (and it's made from black plastic rather than white). So if you're trimming that off to make it fit then perhaps you're better off getting the 123, which seems to be essentially a pre-trimmed 124...?
This was what I was about to say - surely the spring is the one part you don't want to be too beefy, because it's the bit that's supposed to be "saving" your servo.
Well I'll stick to the 123 and if I get issues I'll move to the 124. Should I have issues with the 123 though if that's WoodiE's standard recommendation in the stickies?
Can you show me what your servo saver looks like on your servo?No, I don't have a YouTube channel, well, not for RC cars anyway.
The servo is the red one mentioned in my thread here:
https://www.arrmaforum.com/threads/project-senton-3s-finally-ordered.17291/page-4
The servo saver I was told to get was a Kimbrough KP123 (recommended on here by WoodIE). I got it on eBay for under £5 delivered.
Maybe wait for the radio to arrive and do the servo and radio at the same time to save getting it all out twice?
Sadly not. Well, not without taking it all apart and removing the servo entirely from the truck, which would be a bit of a ballache! Are you just trying to figure out which bit it is? The servo is mounted upside down in the Senton, which is why it's a pain to show, because it's not visible just by pulling the body off the truck.Can you show me what your servo saver looks like on your servo?
On the stock stuck the servo saver is a red round piece on the top of the servo. It's the big round plastic lump that connects the servo to the steering components.No problem!
You can get the adjustable motor mount and get whaat size pinion you wantThanks guys that's what I went with. The 15t the I upgraded the servo and remote as well!
I have the same on my kraton 4s its a bit stronger than the stock wobbly servo saver but get the black one who is super strongIs this the servo saver?
I wonder if you could have done the body lift like i did on my Senton. I added larger tires and NO CUTTING. check out my posting " Sentom 3s 4x4 mods. I lifted my body, Made a debris deflection system that stopped all the debris from getting into my truck frame, Check out the posting I put ouy about body lifts ect..Yes I did. If you look at this photo you can see the amount I cut out.
