Well if you buy a Brushless motor you also need a Brushless ESC. I will recommend the MAX10 SCT. At that point get the Arrma 3s motor mount, spur, and pinion.Hello all,
I’m new to the RC world and have just bought a Senton 550 Mega. My question is. What is the best but not break the bank Brushless motor I can buy to replace the stock brushed motor??
Kind of expensive there are tons of options . Check out rcjuice.comWell if you buy a Brushless motor you also need a Brushless ESC. I will recommend the MAX10 SCT. At that point get the Arrma 3s motor mount, spur, and pinion.
Max10 is kind of expensive what I meanKind of expensive there are tons of options . Check out rcjuice.com
