senton 6s v3 2.8 tires
Release the kraton
Potterville MI
Kraton, Senton
I have seen a bunch of stuff on people doing bigger tires on the 3s senton but I have yet to see anyone do bigger tires on a 6s. I was thinking of doing some 2.8 badlands on mine and wasn't sure if I would need to cut the body up to make it work. Anyone have any experience with this? as far as I know you cant adjust the height of the body on the 3s version but you can on the 6s so I figured maybe I wouldn't have to cut the body to make it work.
Mrglasso1
Edgerton Wi
Typhon
You’ll have to fit it on with the tires and trim a little at a time. Then run it find where the rub is and trim more. Shouldn’t have to take a ton off. To use bigger tires like that on a senton you’ll need to truggify it or get extended hex’s.
MeesterC
ArrmaForum Fan
Georgia
Kraton, Senton
I use the Badlands on my senton but I use a different body. I didn't like how dirt, rocks and other crap got into the chassis area because of the tires being covered by the body. Once I changed bodies and the tires were out in the open I had less debris getting trapped inside the car.
Similar threads
