Shadows
- Points
- 253
- Kraton EXB
- Senton 6s
I don't know how available the arms really are. It is a discontinued model. I wasn't suggesting full CVD's at the back end, although I did do that for my orange V5 Typhon to Senton conversion. As for the track width, I just mounted the body higher up, using longer posts. Looks fine to me, and the JConcepts F2 body I used actually is a lower profile, so they're all do-able. As far as the build he was talking about, it appeared he was interested in building a 1/8th, LWB chassis (Kraton or Talion) SCT. That's why I suggested the slightly wider Typhon control/A-Arm track to go with a 1/8th SCT body such as Hobao's that would very likely fit well with that. The S6 is made to fit 1/10th SCT bodies. I don't know how else to explain that.Yes, the Senton 6s arms are still available. Run them while they are and the body would fit nicely.
That’s just not necessary at all.
CVD’s are great, but not as necessary with the shorter Senton shafts/arms.
Not sure why you’d think that. We’re talking Senton 6s body here, right? If you go Typhon arms you’ll be hacking up that Senton body to get the clearance while having to mount it really high. And it would still rub on landings or hard compression.
As far as my S6 from Typhon parts build, I made sure that the body absolutely will not make contact with the body.
But, again - he was talking about an interest in a 1/8th (LWB) ARRMA chassis. I do realize he was talking about a truggy version of it, but I thought I'd show that if he ever did want to make a full-on SCT (the body) in a 1/8th scale, that it is an option. Stock S6 track width for that would be a bit too narrow. Typhon width would be spot-on. Would sure beat having a Mojave 4s imo.
