BLX Senton 6s
Discussion in 'Senton 6S BLX' started by Wreckless, Feb 5, 2018.
Tags:
  1. Wreckless
    Wreckless Well-Known Member
    Jan 28, 2018
    7
    1
    Ontario Canada
    Arrma RC's:
    Senton
    Hi all
    I am new to the RC world. When I bought the Senton 6s, I was debating between a 4s lipo or a 6s lipo. The person at the hobby store recommended 2 - 3s lipos. I thought it was a good idea, as he mentioned I could run a 3s to learn on then run 2 - 3s together. Once I was home and read the owners manual, the book said to run
    2- 3s lipos.
    I am running a Gens Ace 7000mah 60c/120c
    Should I run 2- 3s or am I able to run on 1- 3s lopo?
    Also;
    2- 3s lipo's won't fit in the battery compartment and was told to hot glue them together.
    Is it safe to hot glue 2 lipo batteries together?
  2. bigred
    bigred Well-Known Member
    Feb 5, 2018
    1
    Arrma RC's:
    Senton
    Safe? Sure. Recommend? Not really. Better off with a thin Velcro strap or two to keep them together. Two 3s lipos do fit, but maybe not the ones you spec’d. I think it’s nice how the battery compartment lifts up to fit two or one. But you can also run one with the adapter.
  3. B0III
    B0III Member
    Nov 24, 2017
    22
    4
    You can run 1 3s lipo, you just will have to watch the LVC, I don't know if the blx185 esc supports 3s. It will run though
  4. chevys10zr2003
    chevys10zr2003 Premium Member!
    Aug 29, 2016
    931
    317
    Minnesota, USA
    Arrma RC's:
    Kraton, Senton, Typhon
    The BLX185 does support 3s. I've ran my Typhon and Senton on 3s numerous times.
  5. Wreckless
    Jan 28, 2018
    7
    1
    Ontario Canada
    Arrma RC's:
    Senton
    Thanks every one
    The people at the hobby store said I could. The manual said to run 2 x 3s batteries. I have been reluctantly running it on 1 3s hoping I wouldn't destroy the battery.
    It seems to be doing ok and the battery voltage is draining evenly with no swelling.
    The power is down a bit, I have a tendency to turn the control knob full at times, so running a single 3s suits me just fine for the moment
    Thanks Again
  6. arrmaracing
    arrmaracing Well-Known Member
    Jan 11, 2018
    256
    66
    Sydney
    Arrma RC's:
    Fury, Kraton, Outcast, Senton, Talion, Typhon
    If you have the senton v3 you definitely can fit the x2 batteries because its the one fitted with velcro straps but the senton v2 are not and you would need to remove a few spacers to make it fit.
  7. Wreckless
    Jan 28, 2018
    7
    1
    Ontario Canada
    Arrma RC's:
    Senton
    The original straps were to short. I bought larger straps that will work, instead of using hot glue to glue them together, I'll get some industrial adhesive to keep them together
  • Welcome to Arrma Forum
  • Disclaimer
