LudeNation
- Texas
- BigRock 4x4
- Granite
- Infraction
- Notorious
- Senton 3s
Turning my Senton BLX v3 3s short course truck into a speed street truck.
Yes it's is, still need to add the front & rear parts.Is that aluminum on the chassis?
They are bolt on skid plates. Not a chassis replacement.Is that aluminum on the chassis?
I got the cheaper option with just the engraving over the full Arrma cut out. I will say the bottom plate came all scratched up. Plus 1 of the pre drilled holes sits directly under the motor so you will have to drill and countersink your own hole(pik below). It comes with 6 nylon spacers 2 short 6 long with no instructions on where to put them.They are bolt on skid plates. Not a chassis replacement.
GPM stainless plates.
https://www.ebay.com/itm/154708548594
Still contemplating getting a set myself.
