Kraton Senton diff in front, Kraton in Rear
Jaymelz324
sup guys question... I have a senton I that i replaced the rear diff in with kraton spiral cut gears. Is anything being damaged due to the difference between the front and rear gear ratios?
The front ratio is 3.31 to 1 and the rear is 4.30 to 1. This may cause the front wheels to slip and the rear wheels to drag. I t will also cause increased wear on gears inside the center diff. The car is definitely going to have some handling issues.
Thanks for the reply.. Im going to change out the front input gear and diff also
You are effectively adding front overdrive... It's often used in crawlers for a tighter turning circle and easier getting over obstacles. But rarely with 6s power so I'd advise against it in a Senton :D
You could try it out on a loose surface, just for the heck of it.
I should have clarified that this USED to be a senton, but i converted to outcast with bigger tires and all that
