paledrifter87
Arrma senton mega throttle not working unless I push the car. Servo works fine.
Could you be more descriptive?Arrma senton mega throttle not working unless I push the car. Servo works fine.
new? old? changed anything?When I roll the rc on the ground while holding the throttle the motor will accelerate, but when stationary the motor will not budge.
I'm doing everything to hold my laugh. STOP IT!You also might want to post a video of the sound that it’s making. Take your video, post it to YouTube and then copy and paste the link here.
Sounds like a stripped gear.Completely stock and less than 2 runs, battery is fully charges tested 2 out to make sure it wasn't battery. Not really making a sound other than gears turing and motor accelerating.
Back to a possible loose pinion like he mentioned. Time to learn how to pull it apart and check things.How come the motor doesn't rotate when I don't push it then?
yeah sorry for not being clear enoughoh the actual motor shaft doesn't spin unless you push?
are you able to post a video of it?yeah sorry for not being clear enough
For real? For really real???I just hit the motor with a hammer fixed it
