Ryan Donaldson
- Talion
- 4x4-Mega
Anybody running a 17 mill adapter on senton mega
It looks like those rims don’t have an offset how does it handle?I run those on mine they work really well especially with a little shiming. I used a 1mm teflon shim.View attachment 16345
Where does it leave a gap that needs to be shimmed?I run those on mine they work really well especially with a little shiming. I used a 1mm teflon shim.View attachment 16345
Where did you get those shims?Between the wheel adapter and hub/bearing like where your normally shim a wheel. Its the little white thing between the two parts.View attachment 16691
Hope these help. If you need more just ask.View attachment 16687 View attachment 16688 View attachment 16689
Something like this? Do you know the exact dimensions? I’m sorry, just want to make sure I order the correct ones. LolI had em in my part box but you can find em on ebay or tower hobbies or just about any hobby shop usually there metal but i just happened to have some teflon ones.
Wonder if these will work?I wonder if metal washers from Home Depot or Lowes would work? Small diameter washer are thin, maybe they're thin enough. Or even thick enough to use just one. I know they also sell nylon washers. I just don't know if they make them that small.
