slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
No it needs to be 8mm long.I don't believe there are any spacer sets in 5mm I.D., especially in aluminum. However, you may have to use some 5mm washers. Not sure if any of these will work for you:
https://www.amainhobbies.com/search?s=5x8+washer+shim+spacer
https://www.amainhobbies.com/search?s=5x10+washer+spacer
https://www.amainhobbies.com/protek-rc-5x11.5x0.2mm-differential-gear-washer-10-ptk-h-5912/p188800
https://www.amainhobbies.com/search?s=5x14+washer+shim+spacer
