It was stuffed before the park but as I hadn’t run the truck for a month as snapped chassis I actually forgot (thanks to head injury) it was basically cooked before.Concrete and RC bashing isnt the best combo... First thing I ever broke on my typhon was on my first ever visit to the skatepark too. Fortunately it was only a front damper top mount bolt in my case..
Broke chassis at bmx track by one awful landing... head injury is from motorcycle accident March13 - they lost me on the table 4 times 25 hrs surgery 14 blood transfusions- u name it I broke it and big time. Double compound left femur just to give u an idea. And tomorrow I go to see surgeons to sort reconstruction of my arm.Awe dude... don't tell me you broke the chassis on your nut... then forgot what had happened. Seperate injury I presume?
I’m living a mild version of “?50 first dates” - & it ain’t that bad.
Thanks bro.....Wow.. must be tough but at least you are taking the positives from it..
Both my brothers had bad injuries from bike accidents and my cousin Ian died last year after coming off his Ducati on a remote country road and not being found for several hours. I'd still have one though... well.. if I didnt have any kids.
Hope you get well soon brother.
@Notorious J - Yes Sir my PowerHD IS water proof or I would not have bought it!But is it waterproof? Winter's coming and the necessity for waterproof just increased 10 fold.
I think that the specs are wrong. I googled this servo and found the same specs online as well. 32kg/cm is actually 444 oz/in I believe.I run an OMG servo in my Noto. Fast, strong and IP67 rated.
OMG-ST-32CF
Modulation: Digital
Motor Type: Coreless
Dimensions: 40X20X38mm (1.57X0.79X1.5in)
Stall Torque:
[email protected](500oz-in)
[email protected](556oz-in)
Weight: 79g(2.79oz)
Speed:
[email protected]/60°
Case: Full Aluminium Case
No idea about thos figures I only look att the kg ratings ?I think that the specs are wrong. I googled this servo and found the same specs online as well. 32kg/cm is actually 444 oz/in I believe.
That's understandable. I just wanted to point it out for the people that use oz/in. I also found it odd that it produced the same torque at 7.4v as it did at 8.4v.No idea about thos figures I only look att the kg ratings ?
Definitely waterproof lol.I run an OMG servo in my Noto. Fast, strong and IP67 rated.
OMG-ST-32CF
Modulation: Digital
Stall Torque:
Weight: 79g(2.79oz)
Speed:
I had the torque correct. The speed was wrong. I've since edited it.it looks like the OP @bicketybam made a mistake on the PowerHD DW25LV specs and listed the 4.8V specs as the 6V specs. The actual specs are:
PowerHD DW25LV
Torque(4.8V): 21.0 kg-cm (291.6 oz/in)
Torque(6.0V): 25.0 kg-cm (347.2 oz/in)
Speed (4.8V): 0.13 sec
Speed (6.0V): 0.11 sec
if these specs are accurate and the servo is reliable, it makes it the best choice foe 6V.
While testing their speed with no load, with a Tactic Tx/Rx and a cheap motor/esc combo, while doing fast movement from left to right (and vice versa) with the steering wheel, the Rx led shut-off during ~1 second, leting the servo in his last position without moving, then the led on the Rx turn-on and the servo can move again and everything work again until the next shut-off. And sometime, by only moving the steering, the ESC give a very short time of throttle, weird behaviour. And this doesn't happen sometime, it happen constently if you move the steering wheel fast during 3 or 4 seconds. I tested it with the BLX100 ESC and an other Tactic Tx/Rx, same issue. I did the same with the second servo, no issues. Sooo, roulette russe servo, i'm really not confident with the one which make the Rx give throttle on the ESC only by moving the steering wheel and turn-off the Rx at moments. Buy it at your own risk ^^ or to be more clear, don't buy it.
