- Infraction
- Kraton EXB
Setting up Infraction V2 with DX5R, when setting the steering servo and brake servo, do you set yours at the hard limit or leave yourself some unused travel? In one direction there's a pretty hard limit as you hit hard parts, so I was going to set a few % off of that as a cushion, but just curious if I should mirror that for other direction or go to max travel there. Also the brake servo do you just keep it at 100%? Not sure what to use there as the limit, can't imagine that would cause issues if travel is "too far" since it is so infrequently used, and momentary.
