Servo for big 3.8 tires
Thread starter #1
ManhattanRC
Likes
4
Senton
Hello,
I've got a kraton and I just bought a pair of Duratrax Banditos, and Proline trenchers. Anyhow on grippy surfaces I noticed the servo doesn't necessarily have the power to snap back, and I figure it's because of the wide grippy footprint of the tires.
What servo would be able to handle tires of the size and weight and not have to overwork? The rest of the car is stock.
bicketybam
ArrmaForum Fan
Likes
1,093
New Milford, CT
Granite, Kraton, Senton, Typhon, 4x4-Mega, Notorious, BigRock 4x4
I just started running Trenchers and I use a Savox 1256TG. It works well but it is not waterproof. Upgrading your servo mount will help as well. The stock plastic mount flexes. No matter which tires you run, the stock Servo has to go before it dies.
Thread starter #3
ManhattanRC
Likes
4
Senton
Is arrma just real weak in the service department? It seems to be a major area of complaint.
bicketybam
ArrmaForum Fan
Likes
1,093
New Milford, CT
Service or servo? If you meant servo, all RTR's have crappy servo's. It's not just limited top Arrma. I always upgrade servos in my vehicles, no matter the brand.
Thread starter #5
ManhattanRC
Likes
4
Senton
Yup. Meant servo. Outside of My Arrmas, I'm a Tamiya fan. I use tactics servos which are good for the size and weight of the Tamiyas. Since the Tamiya does not come with servos, I've never had to consider stock until I started buying arrmas.
I just ordered a savox 1210 for my kraton based on the fewdfeed from the forum.
olds97_lss
ArrmaForum Fan
Likes
374
I run that on my outcast with 3.8" trenchers. I had to tighten the saver up some and still need to tighten it a bit more. The servo has the power, but the saver seems a bit soft yet.
Similar threads
