Kraton Servo replacement info
joe13146
When I purchased my truck new, it had a servo issue and they were supposed to replace it under warranty. But 3 months later, I still haven't heard from them. So what does everybody think about the promodeler ds635blhv? And what other parts do I need to make it work Properly?
Looks like a good servo with some things to keep in mind.
Its not recommended to use with a BEC and has a 15 tooth spline.
I'm running a stock esc and the 15 tooth spline looks much beefer
So a external power source is recommended (though the bec could still power it).
I just mentioned the 15 tooth spline as it's not the more common between 25 and 15.
It is a good looking servo though...will give you good power.
Thank you
