Thanks! How do you like this servo saver?I just put my stock one over top and noted which hole lines up. Then trimed off everything with a knife or side cuts leaving only the part from the main body to that hole. Ensure the material left comes straight off the body to the hole and not at a weird angle.
https://www.arrmaforum.com/threads/standard-process-for-replacing-a-servo.23266/#post-321964Anyone have tips/videos showing how to trim and install a Kimbrough 124 servo saver?
