Kratonlover723
Hello again,
So I started to take apart the steering of my Kraton to tighten the servo saver, but I ran into a problem almost as soon as I started. When I unscrew the 2.5mm screws on the top plate, nothing happens. Then I saw the 2.5mm screws on the bottom and figured, "I'll just stick an Allen wrench in those to keep them from turning." Well now when I unscrew the screws on the top, the bottom ones unscrew. I found in the manual that there is a post inside of each bellcrank that the screws go into, and I assume that it's turning instead of the screw. Any suggestions?
