No. You can run your car however you want.Do I have to use a servo saver?
Need the servo saver. Like stated above.I have a Kraton 4S v2 and ordered a new servo. Do I have to use a servo saver?
(If not). Can I just use a new horn and connect it to the fix link?
Thank you
Hi I have a kraton 4s v2Everyone will say to run a saver.
I have an Outcast 4s V2 and Kraton 4s V2. Both I run a horn with no saver. My servos are all metal geared 35kg. Have run many packs though both of them, jumps, cartwheels down the street, etc. No issues at all, and steering is awesome. I am a decent driver, so no crashes into anything or bad landings direct to the front wheels, so can't say how it would do if that happened.
I hate the 3s/4s style servo savers. I ran the Kimbrough 124 saver in them, but still didn't like it, so switched to an aluminum horn.
So not telling you that you don't need a saver, just my experience.
Hey there, I noticed you said you ran a horn with no saver. I tried to do the same with a protek horn and stock link. But I am having clearance issues where the link drags. Is your link on the top of the horn or in between the horn and the servo? Hope that made sense...Everyone will say to run a saver.
