Typhon Servo screws wont tighten up.
Titan
  1. Typhon 6s
Hi guys, I've been going round the typhon ensuring everything is tight but I've noticed the 4 top screws for the servo won't tighten up.
Anybody else have this issue and what's the best fix?
Also have same issue with 2 screws that hold the upper shocks in place.
Stripped? Get an aluminum upgrade servo mount while you're at it?
Upper shock mounts: you need to tighten the collars/perches/tubes/mounts that are over the bolts. Remove the nut, slide the shock off, tighten what's left, reinstall shock, tighten nut.
After going round the car I've found several bolts wont tighten fully into the plastic.
The cars only had 3 runs. Its nearly brand new.
You stripped the threads in the plastic or they came that way from the factory...
Fix it with CA glue, use longer ones if they fit, use a nut on the other side if it's open... Part of the hobby. Screws in plastic should be just snug, half a turn too much can ruin the threads...
Which ones, btw? There are some that are screwed into stuff that rotates with them.
