SSSF
Just installed a new servo: JX CLS-HV7346MG 46KG
I am using the standard arrma remote and receiver: arrma tactic ttx300.
I have set the remote to center with max servo endpoints, when i steer I get roughly only 50 degrees of travel.
The servo is strong enough, so it does not matter if I put load on front or not.
With the steering trim in addition to steering I can get a lot more degrees of movement (add 20 degrees to the 50), so the servo is working correctly.
Is there a way to further increase the travel with the ttx300?
Did, for instance, somebody opened the ttx300 and change the resistance of the servo endpoint potentio meter?
