Lower wing mount bolts sheared clean off.
Drill, tap, SOL?
Any input would be greatly appreciated!
Drill, tap, SOL?
Drill, tap, SOL?
This is how I did it. Worked like a charm.This happens... You need to remove the shock tower. Once you remove the bolts that hold the shock tower on you will wiggle it rearward off of those sheered bolts. Once the tower is off there will be enough of the broken bolt sticking out that you can get pliers on there and unscrew them.
