GreatWhiteDope
Hey guys, got a bit of a long one here, really need some help with my current situation on my K6 EXB v2.
Recently I installed 3 arrma aluminum diff cases. Not sure exactly what’s going on, but they fit horrible on the v2. My guess is maybe they designed them for the plastic diff housings? Anyways, on my front & rear diff, I have had to tinker and change the shimming up several times. On the diffs themselves I can’t fit a shim on the ring side as it just won’t slide into the housing with it. I removed the factory shim (.2mm) from the pinion as it was basically making it rub on the diff case. So no shim was causing to much play, so I decided to add a (.3mm) shim to the outside of the pinion (input cup to outside bearing). Seemed to get rid of the play, and there’s just barely enough clearance to keep the diff and pinion from rubbing. (Pic of clearance with shim)
Now to the center diff, idk what’s going on with it to be honest. I noticed the aluminum diff case was rubbing the hell out of the diff mount and wrecking havoc. Also there was a ton of play for some reason. So I added a shim to the non-ring side to push it further away from the mount. Still a small amount of play, but adding a shim to the ring side made it to tight.
With all these changes the truck drives pretty good, but gets somewhat unpredictable sometimes and feels like maybe my mesh’s aren’t great?
I’m pretty new to the hobby still, and not sure I have a 100% understanding of shims.
Quick overview of the diffs atm,
Front is 80k open, center 500k open, rear 100k open. Truck has the HW 4990 combo in it. I’ve changed my fluids alot trying to find a good setup, anything lighter then 80k seems like it’s just getting cooked(smells that way after a couple runs).
So basically is where I added the shim okay? How can I tell if my diff/pinion mesh is correct? Ideally how much clearance am i looking for between diff/pinion?
Any insight and advise would be appreciated.
