Guidoune
do you shim your front rear diff? if yes ! what do you take for to do?
I don't understand what you are trying to ask. Yes it helps to shim your diffs.if yes ! what do you take for to do?
Thanks for the help manI use TLR diff oil. 125k f 500k c 30k inthe rear. A lot of good drifting in loose dry dirt.
Where can you find that shim kit
Is it safe to assume I need one kit per diff?These have worked as well.
https://www.amainhobbies.com/mugen-seiki-differential-washer-set-muge0206/p3241
Oh sweet.No! One will do all 3.
