Gloggen
How tight do you shim your diffs?
When I shim one of my diffs I can either use one shim less than in Thomas P:s fantastic video about bulletproof diffs making it feel smooth like butter when turning the outdrives (is that the correct term?), OR I can use the exact same amount as Thomas, and I will feel a soft clicking as the gears turn into each other.
There’s no ‘binding’ if that means that the mesh is so tight that it jams, it’s just that I feel the gears turning.
Thanks,
Joel
Thanks,
Joel
