Should all models of 6S be shimmed?
Right on. I just received a V4 typhon I got from eBay bout an hour ago I'm going to use for my new build. Air compressored it clean and slapped a battery on her to see if she turned on and got nothing. Looks really clean and in good shape. Is there any way to test the esc?It’s hit or miss I guess. Some say they are good and don’t need it but from what I saw on my V4 Typhon that I bought new was that it needed a shim in the front for sure to better engage the pinion/ring and I think it also needed the same one in the rear as well.
Personally, I would just check it along with the fluid level inside the diffs. The front and center diffs were leaking on my Typhon due to the screws being too loose on the center diff and the gasket being torn on the front diff.
Moral of the story is, just check everything to be sure it was assembled correctly.
I have one, not sure how to do that though.Good deal you’re gonna love it!
On the ESC, do you have a multimeter? If so you can check the resistance between the pos and neg power cables to see if they are actually connected to the board underneath.
This link explains it pretty well.I have one, not sure how to do that though.
