bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
I have written this elsewhere but I wanted to break it out on its own for people to find easily. This is how you should approach the rear differential of your new Kraton EXB:
Open up your brand new rear diff on your new EXB. Pull it apart and clean whatever fluid is in there. You will need the two types of shims that are used in the diff from the factory: ARA709059 and ARA709060. When you reassemble the rear diff you want to start with the larger (in diameter) of the two types of shims and put that over the o-ring. Then you want to add a combination of the two shims so that you can get the pin through end of the outdrive and not have the outdrive move in and out. You want it tight but not so tight that it's difficult to turn the outdrive. You then do the same with the other side. Dry fit the rest of the diff together and check for smoothness. It should not feel crunchy/notchy. You should feel the gear teeth as you turn the outdrives in opposite directions but nothing more that that. If it's too tight, open it up and remove a shim. Reassemble and test again. Rinse and repeat until it feel right. Then you can add your desired weigh of fluid and run the diff in your truck.
Hope this helps.
Hope this helps.
