Typhon Shock alternatives??
Dietrich_40
Minneapolis MN
  2. Nero
  3. Talion
Does anyone know what shocks work on the typhon besides the stock? I have been unable to find a set of stock ones and have heard your can put talion fronts on the typhon rear. Not sure what would work on the front of the typhon though. Could really use some help...
The only other shocks I know of that are pretty close in size are out of stock.
Fronts https://hobbyking.com/en_us/1-8-alu-shock-absorber-set-106mm-2.html
Rears https://hobbyking.com/en_us/1-8-alu-shock-absorber-set-126mm-2.html
Tekno SCT410 shocks should fit iirc @chevys10zr2003 has them on his, but Idk if you are looking to spend $100+ on shocks plus you have to piece them together yourself.
Hot Bodies shocks again $$$
Front https://www.amainhobbies.com/hb-racing-112mm-big-bore-shock-set-hbs113466/p413226
Rear https://www.amainhobbies.com/hb-racing-124mm-big-bore-shock-set-2-hbs109830/p250768?r=0
I know that I have the SCT410.3 front shocks on the front of my Typhon. I believe that I have the NT48.3 front shocks on the rear of my Typhon. It's either the NB48.4 or the NT48.3 fronts. I can't remember which one exactly (they are the same shock regardless) but I remember that they were the mostly optioned out shocks and from a nitro model. They were like $10 more than the SCT410.3 rears, so I got the optioned out model.
The only thing I had to do was grind out a tad in the front A arms to clear the larger rod ends.
