Shock bladder collapse
PTM PETE
Hi all
Does anyone know why my sock bladder aren't holding up. 3 out of 4 line this
I had one do the same on my Typhon last night. I will be here waiting for smart people to respond with you :)
It's a bit strange, everytime I rebuild my socks they loose consistancy, everything still stock but it's not as plush as it was when I first got it
In going to put shaped piece of sponge under the dome, might help a bit
Full compression of shock shaft & allowing shock oil to leave the body before tightening cap in place.
Oil does not compress and if the shock shaft is extended when tightening cap, the oil displaced as the piston go's into body along with shaft ... diaphragm gets displaced and will take a set in such a manor.
