What are you guys using for wrenches/ pliers to disassemble shocks? The shock body measures 23mm. Are there specific tools you guys are using to take caps off? I have some stubborn caps on some Jenny’s Typhon shock purchases.
The spot for the 17mm on the wrench is for grasping the shock body? The reason I didn’t get one of these is because when I mic the hex on the top ie reads about 23mm. If this is the case I’ll order one today...https://www.towerhobbies.com/cgi-bi...MIic6H16vM4gIVhlmGCh1XuAt8EAQYAiABEgIVpfD_BwE
https://www.ebay.com/p/Tekno-Racing...MIysqL86vM4gIVT2eGCh0TqQ8mEAQYCiABEgLtXPD_BwE
I use these except I don’t have the Tekno pliers (wish I did) but I have the HR pliers.
Are you measuring flat to flat or point to point? The shock tool below is the one that I have and I love it. This is probably one of my tools that I will never go without again. At first I thought it was stupid and pointless but I got it and tried it and love having a proper shock tool to work on shocks as well as install and remove pivot balls.The spot for the 17mm on the wrench is for grasping the shock body? The reason I didn’t get one of these is because when I mic the hex on the top ie reads about 23mm. If this is the case I’ll order one today...
Yes, flat to flat. If it works on your Arrma shocks the number on the wrench is in reference to the shock type not actual size of the flats. 12/17 or 16 on the wrench makes sense.Are you measuring flat to flat or point to point? The shock tool below is the one that I have and I love it. This is probably one of my tools that I will never go without again. At first I thought it was stupid and pointless but I got it and tried it and love having a proper shock tool to work on shocks as well as install and remove pivot balls.
https://www.amainhobbies.com/tekno-...-sA_DYh0IHQFDfXVnpTDSiH1Wjv0MChsaAqvCEALw_wcB
I'll try to check mine tonight when I get home to make sure that it works. It's been awhile since I've taken any of my shocks apart to be honest.Yes, flat to flat. If it works on your Arrma shocks the number on the wrench is in reference to the shock type not actual size of the flats. 12/17 or 16 on the wrench makes sense.
I'm using this one, works amazeballs.
https://hobbyking.com/en_us/shock-tools.html
Thanks. I have a set of caps that are stubborn. They aren’t coming off by hand.I'll try to check mine tonight when I get home to make sure that it works. It's been awhile since I've taken any of my shocks apart to be honest.
That's right. I completely forgot about the Arrma shocks not having that hex on the bottom. I upgraded my V2 Typhon to Tekno shocks because I kept bending shock shafts back when they were 3.5mm shafts and then I upgraded my Kraton to Tekno shocks after I tried doing some maintenance on the stock ones and bent and gouged the bodies to hell due to this. The only Arrma shocks I have anymore are for my Senton and that is taken apart right now.I don’t think the Tekno pliers will work...I think they only work when the hexes are machined into the bore. Every time I have taken the Arrma caps off I’ve had to put them in a vice and grab that hex...if you look at the Tekno shocks you will see what I mean.
ThanksI forgot too and I’m the bonehead that originally recommended them...sorry @Walküre.
The set @slick2500 suggested will work with any size shock since it clamps the barrel rather than the hex.
Will this work on Arrma shock shafts? Aren't the shock shafts 3.5mm? If so, this tool won't work for that will it?Are you measuring flat to flat or point to point? The shock tool below is the one that I have and I love it. This is probably one of my tools that I will never go without again. At first I thought it was stupid and pointless but I got it and tried it and love having a proper shock tool to work on shocks as well as install and remove pivot balls.
Yes it will. It depends, the V1-V2 shocks were 3.5mm, the V3+ shocks are 4mm. Yes you would put the 3.5mm shaft in the 3 spot, it will still grab it. I use my shock tool to hold 5+mm turnbuckles while I put rod ends on, I just stick them in the 4 spot and it still grabs the shaft just fine.Will this work on Arrma shock shafts? Aren't the shock shafts 3.5mm? If so, this tool won't work for that will it?
