Kraton Shock breakage
Tutur74170
Hello, i broke this part, does anyone know if I have to change the whole shock or if this part exist?
Yep, you can just change the rod end and make sure you adjust the droop screws correctly to avoid braking more rod ends in the future.
Thanks for the feedback, how do i know if they're corrcetly set tup?
You want to set up the droop screws so that you need to compress the shocks a bit (like a few mm) to install them on the truck. That way, they will never go to full extension when driving, which is what breaks rod end.
