Yea I have had the nut come loose on the shaft. I would just make sure it's tight when u put back together. And if u want put just a little dab of blue loctite wouldn't hurtShock came apart. The rod came out, but that was about it. The piston also came loos from the rod
I think most are 80cstIs stock oil rear 1k cst?
The manual says 1000cst, but it doesn't say front/rear. Is it 1000cst all around?
Yea front and rear sameView attachment 201493
This is the only thing I can find in the manual. I'll assume 1k cst (80wt) all around is what is in there.
