Typhon Shock mounting points
Jeremy20081
Does upgrading your lower arms and your upper shock Tower help with reducing shock shaft bending?
It's my understanding that you want to make sure that your chassis is slapping the ground on hard landings as this will take a lot of the strain off of the shock shaft. If your shocks are bottoming out before the chassis hits the ground they're much more prone to damage (i.e. bent shock shafts). I'm no expert on jumping but, just from the physics of it, it makes sense to me.
Do your lower arms have droop screws? If so they probably need adjustment
3s and the original 4s rigs don't have droop screws, only the larger rigs do.. 👍
The rpm arms are more flexible, so they can help to some degree, but bent shafts are typically from some sort of crash/ tumble..
The tower is what it is, unless you put one of those aluminum braces across it.. but shock position will not help with bending shafts..
Larger diameter shock rods are the answer, not much else will help in that department...
Sweet thank you. I bent a shock rod on a jump but it was odd because I landed flat. Makes me think it happened at a different time.
