Shock oil weight suggestions for Tekno springs orange
vale-vox
Thailand
Ciao Guys, i just purchased the tekno orange spring for my Kraton. 80 mm front and 90 mm at the rear, im about to purchase the shock oil but i don't know what to put in it. Can you give me some suggestions on which oil density i should put with the new tekno orange set up? I normally do jumps but not crazy high... Just enough high to do some back flips :) thanks for your support guys!
Uhhh, I could be mistaken but the orange Tekno springs are actually softer than the stock v3/v4 springs... they were a fix for the older models.
Oh... Then i Literally wasted 25 bucks.... Anyhow for the standard springs what oil do you suggest?
Uhhh, I could be mistaken but the orange Tekno springs are actually softer than the stock v3/v4 springs... they were a fix for bucks
he older models.
So sad.... I Will Work harder to recover those 25 usd.. What do you suggest For the oil weight on standard Shocks?
