The last Nero
- Nero
What weight shock oil are you finding to work best? Front and rear
Yea I'll be jumping so what would you suggest? And what comes in them stock does anyone know?Iike 50 in front and rear...great for handling...probably light if lots of jumping
Will do thanks!I think 80wt stock...test out first and see how u can drop without bottoming out...also make sure you lookat the droop of the suspension...basically the stock rod ends are too short and put strain on plastic....I solved with using rod ends from my sabertooth basher on one end....much longer and thicker...if u look...there is not much pressure on rocker...stock is shorter and creates pressure + I adjust shock settings to outer most hole
