Could someone please tell me what the difference is between 20 30 40 etc shock oil weight? One of my caps got knocked loose and I lost all my oil but I don't have a clue which weight I should buy! Any info will be helpful. Thanks in advance
Ok thanks. I'm kinda new to this but I'm assuming the thicker the oil the stiffer the suspension right? Is there some what of a standard that most amateurs use?Hi
The higher the number the thicker the oil is.
Thank you!most vehicles come stock with 30wt but if you check your user manual it should say in there
