No need to disassemble the entire shock, probably easiest to remove the shock from the vehicle first tho. After removing the spring perch and spring, the rod end simply unscrews from the shock shaft.aaahhh nice thanks @#ARRMArcfanboy4life . Didn't realize the online diagram had things in it the book didn't. Do you know if the shock rod end just screws in from the bottom, or is there more to removing it than that? Basically asking if I have to disassemble the shock to replace it
