jimbulsara
- 4x4-Mega
Hi all,
I recently had to replace my front shocks, they came leaking out of the box.
When i tighten the lower screw in the shock (the one that connects to the arm), if i tight it down there is hardly any movement on the shock, i can hardly wiggle it. However, i noticed that on the one that i didnt replace there is some play, that is i can sort of wiggle it with my finger and the shock will rotate slightly. Does this really matter iF the shock can't wiggle so much? was i tightening it too tight? I unscrewed it back a bit so that there is some play. How do you judge when to stop tightening this connector? (Low end of the shock, that connects to the arm)
