Premium members don't see ads. Clickhereto upgrade.
Shock rod end upgrade
smkd13
Ok so after searching the forum and doing some research I found my solution. With the Arrma AR330409 HD rod ends they need a larger ball (6.8mm).
Arrma in their infinite wisdom fails to list that anywhere on their site or packaging.
Tekno has them for $9.99 for 4 steel balls. Today I found that HPI #101083 has the same balls for the wonderful price of $3.00.
The Tekno shock ends need these balls as well. Just wanted to share this and hope it is helpful. Guessing this should be the same durability as the “bombproof” shocks.
Top: Stock
Middle: Tekno
Bottom: Arrma HD
WTF MIKE
Top: Stock
Middle: Tekno
Bottom: Arrma HD
which one do you like better and why?
smkd13
Me personally I feel like the Arrma HD are going to be stronger because of the design but only slightly more than the Tekno. There is more mass surrounding the point where the threads start and the ball starts. In reality both these willl take more punishment than stock. You will break any of them unless you adjust your droop settings.
The HD shock ends provide a slightly longer overall length to the entire shock by ~1-2mm
leo248
UK
Talion
Thanks for this. I recently broke a shock road end so I will be able to fit the HD rod ends that I had in stock properly now.
smkd13
Hey no problem man. Glad I could help I liked the idea of using the aluminum spacers but I feather have the balls there for any Forbes that are perpendicular to the rod end.
Updated the links to better prices
olds97_lss
Bash Break Repeat!
Dekalb, IL
Some of the ball ends are like gold. I bit the bullet and bought the tekno ones with the metal balls, was a bit steep on price. I also tried some dubro ones that were thicker. Both seem to be holding up about the same. I have dubro on the front and tekno on the rear. I had really bought the dubro's to try on my revo shocks/pushrods. I wasn't sure if they would fit so I had only bought 4. At $8 a pair, I didn't want to go nuts and buy the 24 I wanted, $80+ experiment. Haven't gotten around to trying them on my revo's yet. I'll have to drill them out for the pushrods, but I think the 3mm is ok for the shocks. Can't recall if I drilled them out for the outcast or not... I think I did, then tapped them half way as well.
jlitch
Talion
Has anyone purchased longer shock rod ends than the stock ones? Looking for a little more rear droop out of my tekno shocks they were a little shorter than the factory red shocks. +1 for the tekno ends they don't budge if the droop screws are set right.
smkd13
Shock rod ends wouldn’t matter about more droop cause your extending the shock length. It means yes it will go farther down but in turn will go less up because the shock is compressing the same amount
Rcjer Arrma 6s BLX 10
Exup Arrma 6s BLX 8
bicketybam Suspension 19
Slicktmi Suspension 15
Similar threads
