Shock rod ends for 6S cars
rcplanesareboring
30 seconds in driving my new Notorious, I snapped the end of a front shock, part number ARA330608. What are my replacement options?
It looks like there are a couple of different Arrma manufactured upgrades and some aftermarket ones as well.
Depends on what you do. Driving into a pole will certainly break stuff, never broken anything just bashing on flat surfaces. Bad landings etc will do damage but by all means it's 15lbs flying. You control the landings, all up to you, some (or a lot) skill and some luck.
I used the cheapo RPM ends for months and they worked way better than they should have considering the cost. I recently bought all new shocks for my Kraton 6S and the stock rod ends were on them, installed the M2C ZRS emulsion conversion kit and adjusted droop, seems to have solved my issues. When I inevitably break another shock rod end I'll upgrade to Nero HD as recommended by many in the community.
nero ends only broke one in maybe two years droop needs to be set right though
