These will work,just use the smaller ones and you have to round down the ends a little
to fit in the Arrma spring cups.
I think I had to drill the holes a little deeper too but they seem to work fine.
https://www.amainhobbies.com/hpi-ra...0h9I2cRbVS0V0aDoipM70TYG3x_Gasw5noaAq6V8P8HAQ
Yes, shock shaft broke too. I got lucky and found a pair of the shock shafts on ebay for retail price. Thanks for the info!Sorry, but what I see is that Frank needs also an new shock rod. Looks like a broken thread in the rod end.
@Frank,
Do you can compare the shock rod with the opposite side? Maybe you can see if the rod is damaged or not.
Concerning the rod end... The Hobao cups are fitting in the springs and rod ends, maybe they will also fit on the shock rods.
I use the Hobao cups, but I muddled the rest of the set. So I can not check if it will fit..
Are there any other known shock rod ends that fit the Outcast? Mine needs replaced but is out of stock for a month or so. Part of the shaft broke off inside it. Or is there something I can try to remove it. Starting to regret buying those ramps lol. Thanks in advance.
