Nice thanks. Those are shinier than mine!Those will help.
Integy makes a set for Arrma 4x4 3S BLX. They're listed as Granite, but they the fit Senton as well.
Front: https://www.integy.com/st_prod.html?p_prodid=35766&p_catid=492#.YjdE9ZrMJBw
Rear: https://www.integy.com/st_prod.html?p_prodid=35772&p_catid=492#.YjdE95rMJBw
I use them on all of my Sentons.
Reduces flex and helps keep the towers from cracking/breaking on impact.
heya,WD-40 your plastics. Put some simple foam tape on top of the shock towers. Foam will also prevent the shock towers from tearing up your body. After 2 years I'm still using the original shock towers. I jump high and can crash quite hard. However, I don't really crash on concrete, which I'd imagine could still break them.
