The Axial shocks I received work perfect on the front.
There is a seller on eBay his name is citysupermarket that has a nice set of shocks for the senton mega. I contacted him and asked for 130mm and 110 mm shocks and he sent me a link, he is in New York so I had them in two days. I believe he makes them because he has all different sizes and colors but I may be wrong. I been using them for a a couple months now no issues
2- standard size rod ends with metal eyelets, mine eyelets have a built in stand-off, but spacers may be needed to keep springs off the axles.
I looked for a link couldn’t find it but if you look up the seller just email him with the size which is 110mm and 130mm and he will send you the link directly@E36Mtek Are you using them as received on your Mega? I like this solution. Do you have a link for an auction or you did it off eBay?
@ptr1ck Can you provide a bit more detail on the rod ends and Wraith shocks? We might be a little more limited on parts in Canada
I came across these, but same issue with sourcing from overseas...
https://www.ebay.ca/itm/4pcs-CNC-Al...Black-For-Axial-AX10-Wraith-RR10/262990986172
